Die Physik der Hölle
Diskutiere Die Physik der Hölle im Humor Forum im Bereich Sonstiges; A few years ago, the "Momentum, Heat and Mass Transfer" exam paper contained the question: "Is Hell exothermic or endothermic? Support your...
  1. #1 Westfalenland, 15. April 2009
    Westfalenland
    Westfalenland
    10. August 2007
    Selbständig
    "Is Hell exothermic or endothermic? Support your answer with proof."
    Most students wrote proofs of their beliefs using Boyle's Law or similar. One student, however, wrote the following:
    First, we must postulate that if souls exist, they must have some mass. If they do, then a mole of souls also must have a mass. So, at what rate are souls moving into hell and at what rate are souls leaving? I think we can safely assume that once a soul gets to Hell, it does not leave. Therefore, no souls are leaving.
    As for souls entering Hell, let's look at the different religions that exist in the world today. Some religions say that if you are not a member of their religion, you will go to Hell. Since there are more than one of these religions, and people do not belong to more than one religion, we can project that all people and all souls go to Hell. With the birth and death rates what they are, we can expect the number of souls in Hell to increase exponentially. Now, we look at the rate of change in the volume of Hell. Boyle's Law states that in order for the temperature and pressure in Hell to stay the same, the ratio of the mass of the souls and volume needs to stay constant.
    [Answer 1] So, if Hell is expanding at a slower rate than the rate at which souls enter Hell, then the temperature in Hell will increase until all Hell breaks loose.
    [Answer 2] Of course, if Hell is expanding at a rate faster than the increase in souls in Hell, then the temperature and pressure will drop until Hell freezes over.
    So which is it? If we accept the postulate (given to me by Teresa Banyan during freshman year) that "it'll be a cold day in Hell before I sleep with you", and taking into account that I still have not succeeded in having sexual relations with her, then [Answer 2] cannot be correct; ...... thus, Hell is exothermic.
    The student got the only A.
  3. #2 Anfauglir, 15. April 2009
    Anfauglir
    Anfauglir
    18. Februar 2009
    Physikstudent
    Ruppendorf
    Nerd-Mode:
    I´d only given him a B-Grade, cause he neighter mentioned Mariotte nor is a Soul an ideal gas. :eek:
Die Physik der Hölle - Ähnliche Themen
  1. Heizung undicht oder Physik ?
    Heizung undicht oder Physik ?: Hallo, bevor ich mein Problem darstelle, etwas Physik. Nach meiner Kenntnis baut sich z.b. in einem Rohr von 10 m Höhe, wenn ich dieses mit...
  2. Rohrisolierung nach Enev vs. Physik
    Rohrisolierung nach Enev vs. Physik: Ich bin grad über die Angaben zur Rohrisolierung nach Enev gestolpert: ---------- Innendurchmesser bis 22 mm = 20 mm Innendurchmesser über...
  3. Hatte früher in Physik immer ´ne 4!
    Hatte früher in Physik immer ´ne 4!: Fühl mich auch manchmal heute noch auf diesem Niveau.:eek: Aber inzwischen bin ich besser organisiert und kenne Leute die sich damit...
