3 rooms to one joining we want to live in the EC
Diskutiere 3 rooms to one joining we want to live in the EC im Architektur Allgemein Forum im Bereich Architektur; Hello, We would like to remove 2 walls in the ground floor of our house (BJ 1955) and connect this to a large kitchen / dining / living room. Now...
  1. #1 CruzGibbs1975, 22.05.2018
    CruzGibbs1975
    CruzGibbs1975
    Hello,
    We would like to remove 2 walls in the ground floor of our house (BJ 1955) and connect this to a large kitchen / dining / living room. Now the question arises, whether there must be a structural engineer, or whether one can judge it that way. In the current kitchen (outlined in black) the 2 smaller walls are no longer. The two red marked walls are to be removed, the passages in the right wall are no longer available, were probably closed.
    In the right-hand breakthrough, we would set up square beams on the left and right and move one in the other, and an iron girder has already been pulled in at the upper wall to the former bedroom.
  2. 11ant
    11ant
    Bauherrenberater
    RLP Nord
  3. SIL
    Dear CruzGibbs, I advice you to contact a structural engineer or civil engineer for highrise, if you want remove walls, don't neither if they are non- balanced or forced, specifically that at your case a girder is always mounted in an other wall, so no one here will give you an exact answer for different reasons or is able to handel it via short infos.
3 rooms to one joining we want to live in the EC - Ähnliche Themen
  1. Baudokumentation und Live-bilder mit Video-UMTS-Kameras
    Baudokumentation und Live-bilder mit Video-UMTS-Kameras: Hallo, ich möchte hier kurz einen Weg aufzeigen, Baufortschritt und die Baustelle an sich 1. live im Internet oder auf Smartphone...
  2. Multi-Room-Audio mit UPNP und Unterputz?
    Multi-Room-Audio mit UPNP und Unterputz?: Hallo, wir planen derzeit den Neubau unseres Einfamilienhauses. Eine wesentliche Anforderung an den Elektriker ist, dass wir in mehreren Räumen...
  3. Live vom Bau: Trockenbau-Anschluss an Sparren
    Live vom Bau: Trockenbau-Anschluss an Sparren: Hallo, Der Quergiebel ist aus Holz und innen eben mit Gipskarton verkleidet. Das soll nun fertig sein, sagte mir gestern der fleissige am...
  4. Ausziehhaus Living Room
    Ausziehhaus Living Room: ich find einfach "nur" geil :wow . http://www.a-matter.de/ger/projects/Living-Room-pr064-01-p.asp . http://www.Formalhaut.de .
